Need help making blind VE adjustment
Old Aug 30, 2005 | 09:07 AM
SNET Telly's Avatar
Car: 92 1LE B4C
I'm not getting a wide band O2 for a couple weeks, but I just installed a ZZ4 cam to go with my trickflow heads, Holly stealth ram, and headers. I know I need to adjust me VE tables. I was going to just raise them across the board, but wasn't sure how much I should raise them. This will be just a temp fix until I get my O2 sensor. THanks for any help.
Old Aug 30, 2005 | 09:16 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Just watch you O2 voltages in the data logs, and don't trust any WOT values without verifying them with the WB.
Old Aug 30, 2005 | 11:01 AM
11sORbust's Avatar
most of the time you need to remove fuel.
just wait for the wideband, trust me.
Old Aug 30, 2005 | 08:06 PM
SNET Telly's Avatar
Car: 92 1LE B4C
I'll try to wait then,
My idle is real low right now, I've tried adjusting the timing, no change. Where might be a good place to start looking to raise it a little (its at about 600rpm now with surging)
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
86IROC112
Aug 21, 2015 12:39 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
