New motor, ready to start tuning!
Old Sep 16, 2005 | 08:38 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I just dropped in my new motor and I know I need to do some tuning to say the least.
My autoprom package is on order and since I have never done this before I wanted to know where to begin based on the specs of this motor. I suppose I will be using TunerPRO since it comes with the kit.
The motor is a 350 that is .030" over
Compucam 264HR-12 210/220 .480/.480 duration 264/274
Comp 1.52 roller rockers
083 heads opened up to 2.02/1.60
24lb injectors
BBK AFPR
Hedman shorties w/matching y-pipe
CATCO high flow conveter
Full 3" catback exhaust
Right now the TPI is still stock.
Any suggestions would be a world of help! Thanks in advance!!!
Old Sep 19, 2005 | 10:35 PM
91L98Z28's Avatar
Car: Z28
My <i>opinion</i> would be to start with a near stock chip. You've got a docile cam and slightly worked heads, otherwise a basically stock L98.
set the FPR to stock pressures, set your injector constant or BPC or whatever it is in MAF land to match your 24# injectors, fire it up and break it in, then start doing some data logging/wbo2 of easy driving to figure out where you are at and what the motor wants. I suspect that the cam might want a bit different AE/timing curve but it shoudln't be radically different from stock.
just approach it in small steps and learn as you go.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
Bradsaundry
Aug 12, 2015 12:34 AM
