Eprom Query ??
Old Oct 1, 2005 | 05:57 PM
Alan Billingham's Avatar
Car: Camaro IROC
Engine: 305ci
Eprom Query ??
Hi,
Does any one know the number of the standard Eprom chip that is fitted to an 86 5.0ltr IROC, Auto ??
Just replaced my ECM and it came with no Eprom fitted.
Also is the 350 the same as the 305???
Can you see the number without removing the blue plastic cover ??
ECM service number is: 1227165.
Thanks,
Alan.......
Old Oct 1, 2005 | 07:56 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
check out the tech data on the main page. this will tell you everything you asked , yes you can see the broadcast code with the "blue cover on it"
https://www.thirdgen.org/newdesign/f...n.shtml#engine
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
the_nikfive
Aug 11, 2015 02:46 AM
mcconahay37
May 11, 2001 06:07 AM
doc
Feb 13, 2001 01:58 PM
