trouble codes
Old Oct 4, 2005 | 09:29 AM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
trouble codes
just curious i know w/ winaldl u can monitor trouble codes being set is there any program or a schematic to build a cable that somehow reads the abs trouble code??
Old Oct 5, 2005 | 05:21 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I would think the cable is the same one. The "device ID" that is input to the data line will be identified by the device and respond accordingly.
Exactly what "that" is I do not know.
As a guess it would be of the same format as all the other modes within your ECM.
Similar to the "mode 0" call to get the engine ALDL data.
Code:
MODE 0, REVERT TO NORMAL MODE.
;* ALDL DEV MUST REQUEST MODE 0 BY
;* XMITING THE FOLLOWING MSG TO
;* THE ECM:
;* DEVICE ID = $F4
;* MSG LEN 1+85 = $56
;* MODE = $00
;* CKSUM = $29
;* THE ECM WILL RESPOND WITH:
;* DEVICE ID = $F4.* MSG LEN 64+85 = $95
;* MODE = $00
;* CKSUM = $cc
Old Oct 5, 2005 | 06:10 PM
Engine: 305 tbi l03
is there any program that interprets and translates this data?? so that when it spits out code it shows up as what kinda error its gettin? i was just curious as to whether a program has been written for this too? thanks for the reply though its food for thought none the less
Old Oct 5, 2005 | 06:29 PM
JP86SS's Avatar
If you can find out what data is supposed to be coming out, I'm almost certain that creating a "ads" file for Tuner Pro would do it.
Just need to know what to look for when creating the definition file.
I'm just looking through the "ALDL stuff" file index and it is listing some ABS information. A134, A155, A156, and a bunch of others.
See if you can figure out which one your car uses and I'll try to help you with it.
the file is on Craig's site.
Jp
Old Oct 5, 2005 | 06:33 PM
JP86SS's Avatar
My guess would be A134.
Can anyone confirm this ?
Old Oct 5, 2005 | 07:26 PM
Engine: 305 tbi l03
i really have no clue or any idea how to find out....actually im tryin to confirm i built the right aldl cable as we speak i posted a pic of what i made for my cable in a thread. thanks
John
I will look into how to find out what data mine send for abs codes but i dont know where to start looking so it could be awile. but i appreciate the offer for your help i was just curious really but if its that easy i will look into it cause i have an abs light right now but id say thats due to me having no fluid to the back brakes...lol...
John
Old Oct 7, 2005 | 11:20 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
The ABS controller is entirely separate from the ECM. None of the DIY ALDL stuff will help you with ABS trouble codes. Some of the commercial handheld scantools can pull ABS codes, though.
Yup, no fluid in the back brakes might have something to do with it.
Old Oct 7, 2005 | 11:54 AM
Engine: 305 tbi l03
yeah i thought that might be the case so where is the diagnostics port for brake light?? and what kinda conection does it use? just curious but thanks for all the feedback so far.
John
Spanky00185@yahoo.com
Old Oct 7, 2005 | 02:39 PM
Dave_Jones's Avatar
I wasn't aware that ABS was an option on any thirdgen F-bodies.
The '91 Corvette wiring diagrams show the ABS diagnostic terminal as being ALDL pin H.
Old Oct 7, 2005 | 03:01 PM
Engine: 305 tbi l03
i belive its abs i know that i get a red brake trouble light when my car is running now that wasnt there two days ago when i had pressure to the rear brakes.
Old Oct 7, 2005 | 03:28 PM
Dave_Jones's Avatar
The red brake warning light is activated by a differential pressure switch.
Honestly, if you didn't already know that, you probably should spend a little time reading the factory service manual, or some internet articles about brake system basics.
What you've described has nothing to do with ABS. It's also not ECM or PROM related, so I'd suggest that the Brake Board would be a more appropriate place for any further discussion about your brake problem.
Old Oct 7, 2005 | 07:15 PM
Engine: 305 tbi l03
my bad man didnt mean to pench a nerve the only reason i thought it was a brake code was due to the fact that my gm scanner has a setting for brake codes but its not compadible for my vehicle....i just thought about it while i had some extra parts left over from making my serial aldl cable. sorry
John
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
