copying spark map from hypertech ok?
Old Oct 26, 2005 | 12:02 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i have this bin from a hypertech 8D mask.
would it be ok to just copy and paste this into my stock 6E bin and have the same benifits as a hyperjunk chip?
Old Oct 26, 2005 | 02:09 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ummm
Throw it away and forget u ever sugggested the idea :-)
Honestly, its the best answer they do nothing.
They crank cooling fan on tem down to stupid and load the high kpa areas with timing
later
Jeremy
Old Oct 26, 2005 | 02:52 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
$8D MAP doesn't quite convert to $6E LV8 directly either. Just use a stock table from $6E for starters to get the rest of the bugs worked out of any new install.
Old Oct 26, 2005 | 09:28 AM
11sORbust's Avatar
Did you compare the two? IMO, start with your stock table or try another stock table. Then play with your idle. Once you get a handle on that, it will make more sense to manually adjust the tables from stock....your engine will require a different s/a "map" than any other. It'll just take experience to figure out what it wants.
KO1
16
Oct 15, 2015 05:00 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
