injector driver
Old Oct 29, 2005 | 02:55 PM
blander66's Avatar
injector driver
I am converting a TBI harness to a speed density TPI harness. The TBI only had one wire for each injector running to the ecm. Where on the pin out i have lists two wires for each bank of injectors. The ones that i don't know about are the injector low drive. What exactly do these do. Do i need to run the second half of the circut back to the computer or is it just a 12 V source like on the TBI?
Old Oct 29, 2005 | 04:16 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: injector driver
Both TBI, or TPI, injectors have 12v applied to the one side, and then the ecm grounds the other side of the injector to turn it *on*.
So use each injector lead (a total of 4 wires), from the TBI, as a *bank* for the TPI.
The TBI has 2 hot leads, and 2 ecm leads. You'll have to branch each lead of those leads into 4 endings for the port setup.
Hope that's clear.
Old Oct 29, 2005 | 05:08 PM
blander66's Avatar
ok then what pins should i use for the wires at the computer the pin out sheet i have lists
Inj 1357 as C11
inj 2468 as c-12
also in my pin out it lists Inj. drive low at D6 and D7
i have the wires from the TBI injectors running to C11 and C12 right now what would go in D6 and D7?
Old Oct 29, 2005 | 09:12 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
For a 730 that would be correct. The injector wires from the ECM should be put onthe C11 and C12.
The D6 & D7 are to be grounded from the ECM. Those are the ECM injector paths to ground.
Old Oct 30, 2005 | 10:19 AM
blander66's Avatar
So for the D6 & D7 I just need to run wires to a engine block ground?
Old Oct 30, 2005 | 11:58 AM
JP86SS's Avatar
Yep!
69 Six Pack
Oct 5, 2015 07:51 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Bryan F
Aug 18, 2015 02:28 PM
kyleb24
Aug 15, 2015 08:24 AM
