OK, I'm a heretic, but I want to burn Eproms for Mustangs...
Old Apr 25, 2003 | 06:48 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Does anyone know where I can get the equipment to burn Eproms for Mustangs????
I already have Tunercat definition files, UV eraser, and the pocket programmer for GM stuff. I would guess that I need something similar to Tunercat to complete the process for Mustangs.
Old Apr 25, 2003 | 07:16 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
IIRC there is a program called EEC-Tuner or Edit.. Tweaker?
check out any of the stang sites...
Old Apr 25, 2003 | 11:25 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I've heard of TwEECer, or whatever they call it.
It's all goofy stuff. I know a guy who does Ford tuning on the dyno. I've been there for alot of it. All I have to say is they pack the EEC full of the silliest stuff.
I'd switch the Mustang to 730 ECM before I learn all that EEC stuff...
Old Apr 25, 2003 | 02:14 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I might have something for you at www.moates.net
Old Apr 25, 2003 | 02:34 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Manical laughter.............
There were some really fast Mustangs running 749s for a while....
Old Oct 27, 2005 | 10:09 AM
87_TA's Avatar
Would you happen to know what I have to do to make this work Grumpy?
It all seems easy with exception of distributer? Any thoughts?
Old Oct 27, 2005 | 10:33 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
check out the megasquirt pages, they have alot of detail on triggering ignition modules. If you can get that working, everything else is not so difficult. I beleive it was mentioned in your other thread, I think you just trigger a GM ignition module(heatsinked adequately) from the ford reluctor pick-up. Someone also did this with an international pick-up, which I think uses a ford distributor......
Old Oct 28, 2005 | 08:19 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The distributor is the easy part. You can use an HEI module with the F*rd pickup, I believe you have to reverse the polarity? Not sure, but if it doesn't work one way, you can just switch the wires!
The difficult part is the IAC, although, you *could* just not use it by changing a few things in the bin. I know there are a few people here that don't use the IAC, I think it was someone with a TBI.
JP
Old Oct 30, 2005 | 07:30 PM
87_TA's Avatar
JP
Thanks for help, Sorry for late reply..
I am not really concerned about the IAC - can either mount remote GM or just not use at all.
Thanks again..
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
CatmanFS
Sep 19, 2015 09:00 AM
Glowsock
Sep 11, 2015 11:09 PM
