tuning the $6e mask
Old Nov 5, 2005 | 10:24 PM
spacgost79's Avatar
Car: 88 iroc-z
Engine: 5.7 zz4
Transmission: megaraptor 700r4
Axle/Gears: 3.73 10 bolt posi
tuning the $6e mask
hello still verry new to diy tunning.......have read the post on the 165 ecm (The Definitive $32 $32b Tuning Article)i am kinda confused i am running a $6e and i cant find any table (BPW FUEL vs LOAD, msec of inj PW. )in the $6e.....i am using tuner pro rt and an ostrich arap bin......can any body educate me on how to tune the $6e
Old Nov 5, 2005 | 11:54 PM
88TAJeff's Avatar
Car: 88 T/A
that table doesn't exist in $6E. You might try tuning with the MAF tables. What worked for me so far, was to play with the injector constant to get most blm's around 128, then adjust the 1st few values of maf table 1 for idle. A search will yield so much more info.
Old Nov 10, 2005 | 07:37 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I wouldn't suggest making any changes to the injector constant unless you have changed the injector size or increased fuel pressure which does the same thing. Just make the changes to the MAF tables. Go with small changes as it will make a big difference. Work on one rpm band at a time and take copious notes. Do lots and lots of data logging!!!!
The ARAP bin has a huge amount of timing in it as well so keep track of the rpm bands where you ping so you can back off the timing. A rule of thumb would be, however much your retard is set for, back it off that much for starters, repeat until the knock goes away.
Old Nov 10, 2005 | 07:48 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
What's your combo? Is it a basically stock engine? What's changed? What problems are you seeing?
ARAP is a vette bin and has some subtle changes that need to be made before it's used in an F-Body. Also, the spark advance IMO is designe to run completely against the knock sensor, which isn't the best idea for a novice. Start with an F-Body spark table.
Old Nov 20, 2005 | 02:51 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
his motor is a zz4 with holley stealth ram, afr heads comp cams with a lift around .544 or so
Armored91Camaro
Aug 12, 2015 09:41 AM
BMmonteSS
Oct 24, 2011 10:58 AM
vectra28
Oct 27, 2006 12:53 AM
JPrevost
Dec 19, 2003 12:51 PM
