MPG chip and power chip
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
I was thinking of having two chips each programmed differently, one for street with high mpg and one set for power. I would like to have them on a switch, or if i have to, swap them out manually at the track. Is this possible? If so, how would you go about setting this up?
Car: 91 Red Sled
Get into burning your own chips and then get one of Craig Moate's adaptors with the ability to switch between calibrations.
I personally haven't had to even bother with multiple chips for performance/mpg. My multi-calibrations have all been drivability oriented. As in 1 chip/cal is setup for both power AND mpg. Then the rest are based off of this with changes in IAC, cl/op, testing purposes for octane/highway mode AFR, TCC differences, "valet mode" with a lower rev limiter, etc. Things that don't change the way the engine runs so much as does the way the engine responds to my right foot
When a chip is done properly there should be no need for multiple when looking to get max power and max mpg. The major reasons for this is that they use 2 completely different area's of the main maps and have their own "modes" in which they operate. Make sense?
.When a chip is done properly there should be no need for multiple when looking to get max power and max mpg. The major reasons for this is that they use 2 completely different area's of the main maps and have their own "modes" in which they operate. Make sense?
Car: 1983 G20 Chevy
Transmission: 4L60
I use one chip for all of my needs(power, mileage, emissions), short of HEAVY towing. I have one that does not use highway mode, has the PE tuned slightly rich, timing a little late, delayed TCC lockup, etc. for use when towing. Very simple changes that I made to help eliminate the possibility of meltdown.
For example I can have my ECM enter PE mode at 30% TPS and get more power than in closed loop, but it gets poorer fuel mileage.
Car: An Ol Buick
Engine: Vsick
Re: MPG chip and power chip
With EFI, you can tune to have the best of all worlds, for a given amount of octane, on one chip.
High MPG, and Power are in different areas.
If you're wanting to drop fuel costs, then you might try a PROMINATOR so that you have 8 chips at the twist of a dial to try. That way you can play the octance game to the max, and do it per tank of gas.
Car: 1983 G20 Chevy
Transmission: 4L60
Power Enrichment- does just that. It gives extra fuel and takes the ECM out of closed loop. Gives a mixture richer than 14.7:1. Highway mode is just PE mode in reverse. It goes back into open loop, giving a mixture leaner than 14.7:1 under light load for better mileage.
sailtexas186548
Aug 24, 2015 10:11 PM
