How much to get started burning?
Old Nov 14, 2005 | 12:15 AM
FrankenT/A's Avatar
Car: Trans Am
Like the title asks, how much $$ is spent on hardware and programs before I actually have my first burnt chip? Is there a stickie with everything I need?
Is it fairly reliable or is it like burning CD's, some just don't make it?
Also, chips are expensive, are there any that can be re-written or re-burnt?
Funny thing is, all I need is 1 chip (modified stock) and 1 later in the future with heads and cam and all that stuff.
Old Nov 14, 2005 | 11:29 AM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Answers to all your questions can be found in the above stickies. Read Traxions intro to prom burning to start you out right, and yes the chips are very reliable.
Old Nov 14, 2005 | 11:36 AM
Speedy Mike's Avatar
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
chips arent that expensive, like $6 each.. and they can be reprogrammed
Old Nov 14, 2005 | 12:38 PM
BadDog's Avatar
It also depends on whether you stick with EPROM, convert to EEPROM, get just a burner, upgrade to an emulator, want a ZIF, burner/logger as USB or Serial, etc...
Old Nov 14, 2005 | 12:53 PM
EdgesZ28's Avatar
Car: 91 GTA - 94 TPI Suburban
How much depends on what you want to do. If all you want to do is read, change and burn flash chips, read the information on the following link:
http://www.edgesz28.com/edgesZ28/sub...ng.htm#diyprom
However, if you want to do emulation (real-time changes), that is different and you will need to do a little more homework.
Good luck, Ed
Old Nov 15, 2005 | 01:19 AM
FrankenT/A's Avatar
Car: Trans Am
Where are they that cheap? Cheapest I found was $30 for a GM blank chip.
Old Nov 15, 2005 | 01:26 AM
turbotater's Avatar
www.moates.net has stuff
www.xtronics.com has stuff
www.tunercat.com has stuff
but remember being able to burn is of little use
if you do not have some kind of data logging
software to know what you need to do.
how would you like a doctor to operate on you
with a blind fold on? same concept of burning
without datalogging .
Old Nov 15, 2005 | 07:57 AM
BadDog's Avatar
To get the cheap chips, you have to convert to the more modern/common EEPROMs like Moats sells. These require a simple mod to your ECM. Details on Moat's site, I just did it last Saturday...
Old Nov 17, 2005 | 12:58 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
About $150 for everything you need, except the knowledge.
Old Nov 17, 2005 | 10:59 AM
BadDog's Avatar
Originally posted by Mangus
About $150 for everything you need, except the knowledge .
Yeah, that's the real kicker...
eightsixseven
Dec 16, 2024 01:50 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
Bradsaundry
Aug 12, 2015 12:34 AM
