can't burn a 29c256 using $58code
Old Nov 14, 2005 | 06:22 PM
turbotater's Avatar
i ran out of 27sf512 chips so i grabbed
the spare 29c256 out of my firebird
it burns just fine 8d code , i can make any
change i need no problem . i try and
burn it for my typhoon using different
programs i have used before and when
i try and use it on the truck it doesn't work ,
check engine fault . when i try and open it
in tuner cat it says ecm definition file
not compatible and i should use $58
which i am using ..
any ideas
Old Nov 14, 2005 | 09:50 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: can't burn a 29c256 using $58code
which i am using ..
any ideas
You have to load the $58 code in the upper half, or double load it.
It only uses a 128K image.
Old Nov 14, 2005 | 10:13 PM
turbotater's Avatar
so you are saying i need to change
the device end point on a 29c256
chip ? if so where do i end it at ?
thanxs
Old Nov 14, 2005 | 11:40 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Set start of device to 4000, end of device to 7FFF.
Old Nov 14, 2005 | 11:51 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
How do you run out of 27sf512 chips? They should be good for 10,000+ re-writes. You can bin stack using the MS-DOS "copy /b" command. It does a binary copy.
J
Old Nov 15, 2005 | 12:39 AM
turbotater's Avatar
i tune on several different vehicles for
friends . i need to order some more
chips . i do have some 29c256 120ns
chips i wish i could use with my pocket
programmer but it does not recognize them .
thanxs craig for the info
so i neeed to fill the buffer with FF at all locations
to erase it and then start the program at 4000
to work
mike
Old Nov 15, 2005 | 12:58 AM
turbotater's Avatar
ok my illiterate fingers must be pushing
the wrong buttons .
i am still getting the same error message ,
not compatible with this source file ,use
$58 definition file .
i already have $58 chosen as my ecm in
in tunercat .
anymore ideas for the mentally challenged
kid in the back .
Old Nov 15, 2005 | 09:42 AM
junkcltr's Avatar
Engine: 3xx ci tubo
The Pocket Programmer will recognize the AT29C256 chips. I was programming some with a PP the other day. I think it is the "F" key for flash and then the "8" key for AT29C256. The PP has supported them for a long time. Did you put them in the socket correctly?
Old Nov 15, 2005 | 03:18 PM
turbotater's Avatar
yup its in right
i went and put my firebird 8d program
back on it and it worked just fine
i made some changes and it works in the car
and i can read it correctly in tuner cat .
i am just having some wierd issue
tryin to put the $58 stuff on it
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Logan Bryant
Sep 23, 2015 06:51 AM
CatmanFS
Sep 19, 2015 09:00 AM
Glowsock
Sep 11, 2015 11:09 PM
