Disable VATS in $58?
Old Nov 15, 2005 | 09:02 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Under TunerCat, I've got a switch for VATS Diagnostic (which I have unselected) but I think I have the VATS system disabling my fuel injectors - car fires right up, runs about 2 seconds, and dies. Fires right back up again.
'88 Camaro, running a '730 repinned to a '749, $58 code
LOL, meant to ask - where might I find the bit to disable the VATS system? Looks like I might have to do this the hex route
Old Nov 15, 2005 | 09:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not VATS, the $58 code doesn't support it. Probably a little lean on the VE table or BPC.
RBob.
Old Nov 15, 2005 | 09:52 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I just did an $8D swap to $58. To start the engine I did minimal changes to the original BBZB $58 bin. All I changed was the BPC vs. EGR tables to a value of 100 by using the equation I found searching DIY PROM.
The car was very rich at idle. The DIY WBO2 read about 12:1 AFR. I removed about 20%+ of fuel at idle.
Your setup could be rich or lean. That is probably what is causing the stall.
Old Nov 15, 2005 | 04:09 PM
Doward's Avatar
I'll hook up the WB02 tonight, see what it says about the AFRs
Old Nov 15, 2005 | 05:40 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Make sure you put a 2-bar map in it if using a stock BBZB. It will be real rich if you use a 1-bar. Just thought I would mention it because it is easy to forget.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
