tunercat RT
Old Nov 18, 2005 | 05:15 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
tunercat RT
i just started to try to use tunercat. i am using a 165 ecm. with a 6e bin def. my question is when i open up tunercat it is telling me that the ECM is 42. is this right. i cant open my bin up. i have the updated 6e def. but how do i open it up to change the ecm from 42 to read the 6e bin. thanks
Old Nov 18, 2005 | 06:03 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Well,
u need to have the $6E def file, which from the sound of it you do :-)
After that, when u open up TunerCat, look up at the top where it says ecms and click on it.
If u have the $6E file with the other TDF's it should be listed under there.
Just clikc on it instead and open a $6E bin
later
Jeremy
Old Nov 18, 2005 | 10:15 PM
smokefan's Avatar
hey jeremy when i open tunercat and up by the ecm on the tool bar it doesnt allow me to change it. the ECM doesnt give me the option to click on it.
Old Nov 19, 2005 | 12:09 AM
3.8TransAM's Avatar
U need to have the $6E file in the same place as tunercat has the TBI file located, think it $42 or something close.
Relocate your $6E tdf there.
If its not seeing the more than one ecm option as available, u either dont have the correct $6E tdf or u have it in the wrong location
later
Jeremy
Old Nov 19, 2005 | 03:38 AM
smokefan's Avatar
thanks jeremy, i will try it when i get home. i know that i have the file cause tunercat just send me the update via email. i unziped it and i guess i must have placed it in the wrong file. thanks. i will let you know
Old Nov 19, 2005 | 01:02 PM
smokefan's Avatar
jerey thanks for all your help. it works now. i had the file in the wrong place. thanks again
john
Old Nov 20, 2005 | 01:07 AM
3.8TransAM's Avatar
No problem.
I still do it now and then when I have to move files or rebuild a PC and go where are my friggin files! lol
later
Jeremy
ULTM8Z
Oct 2, 2015 01:25 PM
Grim Reaper
May 23, 2001 08:08 PM
Grim Reaper
Apr 20, 2001 10:40 PM
Grim Reaper
19
Jan 28, 2001 06:48 PM
