BPW ve tables okay, ran out of AE
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Hey, tuning this Vortec 4.3 with a 7747, I ran out of AE VS Diff TPS. The top 3 values are maxed, and I'm still way lean on moderate tip in.
AE vs Diff Map is the same way, with the top two values maxed.
Do I need to crank the BPW down to make it think I have smaller injectors? Will that work? Then I can retune the VE tables okay. (which are pretty close to being maxed if combined.)
Winaldl in it's limited reading, looks like I'm .1-.3v while AE is occuring.
RedLeader289
May 28, 2019 01:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Linson
Oct 1, 2015 09:50 PM
