how do you tune in a chip for heads?
Old Dec 15, 2005 | 09:43 PM
Bryan85TA's Avatar
I got 416 heads on an L03 with upgraded cam and valvetrain. Whats changes needs to be done in the chip for tuning heads.
Old Dec 15, 2005 | 11:12 PM
JPrevost's Avatar
Car: 91 Red Sled
I'm not going to give you the exacts but there are a bunch of things the heads effect. One thing they tend to not effect is the peak volumetric efficiency RPM, although they can.
If the combustion chambers are different you'll need to modify the timing. If the compression is different, timing and VE, and everything might need some warming over but not a lot (hopefully). Then there's the real kicker, flow. If the intake and exhaust ratio is very close and the heads flow more than the old then you'll need to raise the VE in some areas, probably lower it very slight at low to mid kpa but not necessarily!
Best way to go about it, if everything else is equal, is to tune the BLM's in closed loop and look at the VE table vs the previous. It'll give you some good clues.
edit; Read bolt above, not the statement is correct
Old Dec 16, 2005 | 12:26 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
BLMs and WBO2
MustangBeater20
Oct 29, 2022 09:20 PM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
