Changing tunerpro map readings?
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Is there a way to make tunerpro display kpa instead of voltage??
Yeah, figure out how to do the conversion (IOW, what math is required) and put it in the ADS file. F4 gets you the ALDL dialog. Click "Edit definition" and go to "Sensor Data" to open that branch of the tree. Look on the right side. Use the Operation drop down to choose the right math, fill out the contant fields (or build a table), change the title (or just create a second Map entry that is in kpa like I did the *C and *F) and save the ADS.
Transmission: 2004R
hmmm, thought is was something like that, now I just have to try and figure it out. Unless somebody has done it already. lol. I justed wanted to see if it could be done. And display the values accurately.
Car: El camino 70 ss
Engine: corvette lt1 94
The od file have 0.411765 (map 105/255 = 0.4117647).
Operation = multiply
Factor = 0.411765
Offset = 0.000000
Unit label = kpa
Range high = 255
Range low = 0
Factor = 0.411765
Offset = 0.000000
Unit label = kpa
Range high = 255
Range low = 0
Transmission: 2004R
Car: check
Engine: check
Transmission: check
Originally posted by liquidh8
ooo. ok. had to open in up and take a look, now i understand.
KPa = (N * 0.369) + 10.415
The factor will be 0.369 as a multiply and the offset will be 10.415
RBob.
Transmission: 2004R
The correct equation to convert a 1-bar MAP in ADC counts to KPa is:
RBob.
RBob.
Re: Changing tunerpro map readings?
I don't understand what I am mulitplying by? My MAP is listed as like 12 - 15v under normal driving conditions is this correct. Am I goint to be replaing N with the voltage? I don't understand.
Thornburg
Aug 25, 2015 01:46 AM
