Changing unit label tunerpro
Old Dec 23, 2005 | 12:38 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Anyone know the offset to change the tempature from C* to F* on my sensors like IAT, coolant, and etc. in Tunerpro? Searching keeps pulling up timing stuff.
Old Dec 23, 2005 | 01:38 PM
BadDog's Avatar
Standard conversion is
F = C*1.8+32
But on the 7747 ADS file I did, the CT temp in *C was based on a table. So I just made a second identical table and used the "Covert C -> F" feature. If your ECM is similar, and *C comes from a table, that's the easiest way to get what you want that I could find. It seems there is no straight forward formula to get from "counts" to *C or *F, and I couldn't find a way to apply a formula to the output of *C lookup table.
Old Dec 28, 2005 | 06:56 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Per Mark Mansur (TunerPro)
Appendix A - Common factors and offset for converting 8 bit (1 byte) binary values to engineering units
These are guidelines and may not always be the case. Consult your hack for verification.
Engineering Unit Factor Offset
Degrees F 1.35 -40.0
Degrees C .75 -40.0
Degrees Spark Advance 0.351567 0.0
MPH 1.0 0.0
LV8 1.0 0.0
eightsixseven
Dec 16, 2024 01:50 PM
Cornholio7979
Sep 20, 2018 02:31 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
beast94
Aug 20, 2015 06:44 AM
tmellott89
Aug 16, 2015 02:58 PM
