MAP Voltage / kPa Correlation?
Car: 1987 Z28 Convertible
Transmission: 5-speed
Unfortunately my scanner displays MAP voltage, not MAP kPa. Is there a conversion formula to derive kPa's from voltage?
Thanks! Looking at it made me think of something else. This table is true only for a 1-bar MAP, correct? How does the 2 and 3-bar MAP sensors compare?
Willie
Willie
Car: 1983 G20 Chevy
Transmission: 4L60
On the two bar, double the KPA for the same voltage. On a three bar, triple it. May not be exact, but it is in the ballpark.
Be careful with that table. I posted that a long time ago as an explanation to a question. While that table should be close (it is a theoretical table) most MAPs aren't quite that linear. You can test with a voltmeter and vacuum pump, and many MAPs are off by ±0.5V or more. Some are high, some are low, but most tend to output a slightly higher voltage than the table indicates at the middle ranges.
