ESC signal question
Old Jan 10, 2006 | 10:20 PM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
ESC signal question
I have an extra "user input" channel on my wideband datalogger. I'd like to read the timing retard signal from the esc to record knock will datalogging. Can I tap into the BLK 485 wire on B7 to pull in this signal? What will the signal look like when the ESC is detecting knock? My datalogger will read a 0-5 volt signal.
Old Jan 11, 2006 | 10:17 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
If it has an ESC module in the engine bay then the B7 signal will be at approx. 9 volts with NO knock. It will be at 0 volts WITH knock.
Can the reader handle voltages greater than 5 volts? If it has an input buffer, some clamps diodes, current limiting, or just a buffered voltage divider then it should be fine. If it has nothing, you might blow the front-end IC out.
If you don't know what it has, the use a simple 2 resistor voltage divider at the input to the reader to make the 8-10 v knock signal a 4 volt signal to allow some margin.
Old Jan 13, 2006 | 05:40 PM
91RockS's Avatar
Car: 91 Camaro RS
I'm checking with the manufacturer to see if voltages > 5v will cause any problems. If I use the voltage divider, do you see any issues that could occur with the ecm due to the added impedence in the circuit?
Old Jan 15, 2006 | 04:20 PM
91RockS's Avatar
Car: 91 Camaro RS
Manufacturer got back with me and said the circuit is protected up to 12v, but recommended using a voltage divider anyway. I'll make up a simple two-resistor divider so the 9v get cut down to about 3.
Caspar
Jun 19, 2016 11:19 PM
db057
Sep 4, 2015 07:57 AM
redmaroz
Aug 16, 2015 11:40 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
