Simple ? on VATS
Old Jan 11, 2006 | 08:35 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Simple ? on VATS
Using TunerCat, with a '91 Firebird ($8D), if I un-check the VATS box do I disable the VATS??? Is it that simple?
Old Jan 11, 2006 | 09:53 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Yep.
Old Jan 12, 2006 | 11:22 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Just to clarify, It will remove the need for the VATS output to the ECM (enabling fuel) Engine will start if cranked.
If you have a start interrupt relay that operates from the VATS it is another issue. ECM does not run it, the VATS module does.
Old Jan 12, 2006 | 01:15 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
What years and where is this start interrupt relay located?
My GTA sometimes just wouldn't crank once warmed up, so I'd hotwire it under the hood (key on, and put +12V to the thick purple wire near the passenger side injectors).
I never had time to diagnose if it was VATS, P/N switch, Ignition switch problem, or whatever, but I'll be back in Cali soon for a short stint, and wouldn't mind spending some time to get that straightened out.
Old Jan 12, 2006 | 02:35 PM
87tpi7749's Avatar
Engine: 5.7L
I have only used $8d with vats removed on TPI conversions, never had a starter interrupt relay, but in all my conversions, disabling VATS would allow engine to start normally without VATS module.
Old Jan 12, 2006 | 05:26 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you all...
Pac J
May 17, 2020 10:44 AM
RS Reaper
Oct 17, 2018 07:52 PM
AmorgetRS
Sep 28, 2015 09:33 PM
mfp189
Sep 27, 2015 09:25 AM
Winchester1094
Sep 15, 2015 09:48 AM
