30.00 for a pocket programmer 2 wall adapter?
Old Jan 13, 2006 | 05:29 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
My wall adapter is bad, so i found one on Transtronics website for 12.00. Not a bad deal...but with 8.00 shipping thats 20.00. Ok.. but i go to check out and there is a low order fee of 10.00.
30.00... where can i get one that will work? Dont they have to be a certain voltage or something? I have a spare setup but want to have two working programmers.
Mike
Old Jan 13, 2006 | 06:43 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Radio Shack? Any electonics store? Just make sure you have the polarity correct (the original adapter should have polarity indication).
I'm just guessing but if you ask really nicely Xtronics would probably waive the $10 "low order" charge if you originally bought the PPII from them. They're a small company and are very customer focused.
Old Jan 13, 2006 | 07:14 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Thanks, I wasnt sure about the voltage ..yeah..I just sent them an email. I did buy the first one new from them.
Old Jan 13, 2006 | 11:15 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It is probably just the 2.5mm (2.1mm ???) connector. The use cheap power supplies. Mine went bad to. It was a broken wire at the connector. Un-screw the power supply plastic piece on the wiring the plugs into the PP. I bet a wire is broke.
EDIT: Radio Shack sells the 2.5mm connectors if the wire at the plug is broke.
Old Jan 14, 2006 | 08:48 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Check out Harbor Freight, they have adapters for $2~ $3.
www.harborfreight.com
Good luck
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
86IROC112
Nov 7, 2015 06:50 AM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
