Highway mode & 3.42's
I'm starting to use my car a great deal on the freeway for commuting and need all the milage I can get.
Can someone with $8D and 3.42's please share with me all of their Highway Mode parameters that seems to work best?
Thanks!
Thanks!
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I don't know if you'll get any define numbers on that. The best bet would be to lean it out and watch your WB. Then play with the HW SA table and keep watching for the best running.
the total fuel output maybe a good way to judge the performance per distance traveled if you go the same route all the time.
Hmmm, then my next question would be who can post info on how to add a mpg filed to the ads file that I can monitor while datalogging that's based on the injector flow rate and the injector pulse width taking into account the 8 injectors and the distance travled etc...
Car: 91 Red Sled
. So here's how to do it. Look at the pulse width, RPM, and MPH. For a commute you will probably be holding a steady RPM so the frequency of the fuel delivery is constant, same with MPH... this leaves pulse width. Lower = better MPG
. Nothing more too it. I take an emulator on a non-busy time of the day and cruise with a driver that isn't "digital" (can hold a steady MPH not on/off the throttle and brakes) and sneak up on the timing and leaning of the AFR. I don't lean out the AFR more than 16:1. I haven't seen any mpg gain by going higher on anything I've tuned, and for a heavy vehicle or high specific output motor that number goes down. Same with gears. With a high reving almost no throttle needed to cruise thirdgen you can get away with the 16:1 almost every time. This is because the specific output of the engine is very low during cruising so it doesn't build up much heat in the oil as would a smaller motor. By running only as much timing as you need (not on the brink of pre-ignition or detonation) the oil temps should stay well within range. Does this all make sense? Thanks. I'll do some more reading up and start on it as soon as I tweak my TCC & IAC issues that remain that I made another topic about.
Then my PROM should be right where I want it
For this week that is, lol.
Thanks!
For this week that is, lol.Thanks!
From the $8D Datastream A100. Haven't done much with this myself but know it can be helpful.
Any logger will be able to display the values.
Will take a little calculating to get it into the units you want but will give results that can show increase/decrease with your changes.
HTH
Code:
Address of data Data stream word #
.word 0x3130 ; 49. IP FUEL, Msec * 0.256
.word 0x3131 ; 50. IP FUEL, Msec * 0.256
; , Total Accumulated Fuel,
; uSec = ([N49] * 256 + [N50]) * 15.26
; Use Time Vs. Injector Constant (Lbs/Hour)
.word 0x0134 ; 51. ACCUMULATED DISTANCE TRAVELED
; Miles = N / 2000
.word 0x3019 ; 52. ENGINE RUN TIME, SECONDS, MSB
.word 0x301A ; 53. ENGINE RUN TIME, SECONDS, LSB
; , Seconds = ([N52] * 256 + [N53])
;--------------------------------------------------- Last edited by JP86SS; Jan 31, 2006 at 08:03 PM.
Car: Death Mobile
Engine: 666 c.i.
Originally posted by JPrevost
... By running only as much timing as you need (not on the brink of pre-ignition or detonation) the oil temps should stay well within range....
92 GTA - I found 17.4:1 and 47* total spark gave me my best fuel economy with a stock L98 TPI car. Play with your AF & spark and take some LONG highway trips. The best I ever I ever got was 385 miles on 12.9 US gallons using the combo above.
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by Glenn91L98GTA
Or, you can increase the spark to increase throttle response (which is needed as you lean things out) and install an oil cooler.
My best ever tank was 721 miles on 31.3 gallons, or 23.05 MPG.
Car: 91 Red Sled
The other thing I'd like to note as important is the strength of the ignition system. No big gaps unless you've got the power to jump it. The CDI's would work well in a lean burn if only to lower the emissions
. TGO Supporter
Car: Death Mobile
Engine: 666 c.i.
Jon, I was the first person to REALLY experiment with Highway Mode a number of years ago (on TGO anyways - check some of the old posts). Before people found certain switches to invoke the HMSA, I had to physically alter the code to make the Highway Spark work properly. This is REALLY old stuff for me and I have since moved on to "bigger & better" things.
I tried a gazillion combos and drove 100,000 miles testing it. The AFR & spark that I mention above gave me the BEST mpg. Oil temps were never a problem. I never burnt out my cat.
I'm only stating my experiences - nothing more.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Highway mode & 3.42's
RedLeader289
May 28, 2019 01:47 PM
