Problem reading stock chip
Old Jan 31, 2006 | 06:41 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I've been trying to read the stock prom for my '86 and it keeps coming back with garbage. I've tried 3 or 4 times and the garbage is always different, but still garbage.
I'm using the Moates HDR1 adaptor with the flash and burn program. I've successfully burned several test bins, and everything seems to be working properly.
The bcc on the chip is ANY3234
there are other numbers on the chip as well ;
69300
D 5012A
and
L636377SX
I plugged these numbers into the search and got no results
I chose the 27c128 chip. Is this the right one? There aren't too many options in the software.
Old Feb 1, 2006 | 11:27 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Have you talked to Craig?
Old Feb 1, 2006 | 04:47 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
When you say garbage, what kind of garbage? Also can you save the bin to your computer?
Old Feb 1, 2006 | 06:26 PM
I figured it out, I mistakenly plugged the usb cable into the wrong port which assigned it to com 8 instead of 3, I just tried again, and saved a perfect copy of my stock bin.
Old Feb 1, 2006 | 07:02 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Post that up on Craig's site if you would.
I don't believe there is one there when I looked for you.
i'm sure someone else could use it too.
Old Feb 1, 2006 | 08:56 PM
It's already there, that is the one I used to compare mine to.
Go to: Stock binaries>> gmecm>>>1227165 >>> 32. It's the first entry.
Ghettobird52
Jul 5, 2024 11:18 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
