Bin too big?
Old Feb 3, 2006 | 09:17 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Bin too big?
I downloaded a bin for an '89 l98 camaro that I want to try in my car, but the file size is 10 bytes too big, will this be a problem? The Moates Flash and burn software adresses the file a little before the 004000 starting point. 003FF6 to be exact
Old Feb 3, 2006 | 11:33 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
That is bad. It needs to be exactly 16K (16*1024) bytes if it is a stock-type bin.
It could be a custom bin that someone made into 32K bytes. You never know what you find out there for bins. Take a look at the last 16 bytes and see were the reset vectors are pointing to.
If this doesn't make sense then do not use that bin. It will probably go into limp mode if you try.
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
