Tunerpro ?
Old Feb 4, 2006 | 12:51 PM
justme's Avatar
Tunerpro ?
Is there a comment section in Tunerpro that I can place comments about a individual bin file (ie what changes I have made to that particular bin) so that when I open it I know them. Thus far I have been naming the bin with key word to help me identify them but they are getting quite long. I am using the 58 code too.
Thanks,
Old Feb 5, 2006 | 01:15 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Tunerpro keeps a change log when you make changes to your bin. Look in the same directory that your bin lives in. It should have the same name as your bin, but has a .log extension.
This can be enabled/disabled in preferences.
M
Old Feb 27, 2006 | 09:32 PM
justme's Avatar
I have the box next to "Enable Edit Logging" under "Preferences" checked but I still can't find a log file after making some changes. Is it only if I save as a new file name, or save file as the same name? I am not getting any log files at all in the same folder. I am only making small changes just to try this feature out but it doesn't seem to be working.
Old Feb 28, 2006 | 05:07 PM
DM91RS's Avatar
Car: 91 RS
The same for me............with the old version I was getting log file notes that would be in the files where I have the bins located.
Old Feb 28, 2006 | 05:18 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
If you do a "save as" you won't get change logs.
Needs to be the same bin, changed and then saved.
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
