Anyone using 2 devices on 1 USB?
My notebook I use for tuning only has 1 USB 1.1 port on the back. Is it possible to have my ALDL cable for data logging AND my BURN1 plugged into the same port using a USB Y-Cable? Is there such a cable and is this possible? I have no idea on the port comminucation works but I'm thinking this won't work since it's emulating legacy serial hardware which needs a dedicated port as far as I know.
Thought I would ask just to be sure.
Thanks!
Thanks!
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Not real for sure on the Y-cable but i wouldn't see why a USB hub at walmart wouldn't work. The only thing i had to get for mine was a cig. lighter adapter so it would have power. Then again i don't run my auto prom off of it. Actually i think Craig has a USB hub listed on his site. IIRC.
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I have ran a 4 port hub to 2 usb to serial adapters and my serial port all at the same time.
running a WB O2-logging, romulator, and aldl cable.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
USB1.1 does support chaining (chaining is a key component of the original USB spec), however a Y harness would not be the way to go and would not work. I don't think such a cable exists anyhow.
A hub is the way to go. Or, as you state, a USB PCMCIA card.
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
My hub is just a cheap little cable hub. It is about a foot of cable and the hub/splitter. nothing to do but plug it into the usb port.
9192camaro
16
Feb 3, 2019 12:21 AM
