What inputs does CCC Qjet need to run closed loop
Old Feb 12, 2006 | 03:47 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I was just over reading posts in the carb forum and wanted to hurt myself after reading what some people "understand" about how cars work. Which is why I'm back here. I was thinking about using a CCC Qjet on a TPI motor for a little while until I set it back up with TPI. Does anyone have a detailed wiring diagram for an 82-85 3rd gen w / CCC Qjet? What inputs do I need to feed the computer so it will happily run closed loop? Is there any way to datalog w/ a CCC Qjet? Just to make sure it is not doing something weird. I am almost tempted to forget the CCC QJet and just run a manual one. If EFI has a problem I get enough data at 8192 baud to figure out what is going on. The computer controlled carbed setups scare me.
Old Feb 18, 2006 | 10:24 PM
32V_DOHC's Avatar
This should get you the wiring diagram.
http://www.autozone.com/servlet/UiBr...3d80163fb5.jsp
Also you shouldn't let the CCC scare you. It is the same type of timing as the EFI and the computer controls the jet "size". Works pretty much like a normal carb except for the closed loop variation of the primary metering area. WinALDL will log CCC if the cable is modded correctly.
HTH
John
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Street Lethal
Aug 13, 2015 08:28 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
