Tunerpro datatracing, 7749?
Old Feb 24, 2006 | 03:52 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i cant seem to get the datatracing to work on the 7749 $58 code, i had it working fine on the 7730 $8d code, am i doing something wrong?
hmm i'm playing back a recorded datalog and i turned it on and i can see it, but i couldnt see it in the car..
Old Feb 24, 2006 | 04:10 PM
ryan.h's Avatar
I've seen that feature, what does it do?
Old Feb 24, 2006 | 05:46 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Some info on it.
https://www.thirdgen.org/techbb2/sho...ht=datatracing
As far as the $58, I'm not sure but be sure the file size (I think) needed to be corrected on one of the XDFs. Was 4000 and should have been 8000 or vice versa. Don't remember.
Try looking at some different versions of the RR files and see the difference.
Does seem odd that you can see it on a recorded file but not RT.
Old Feb 25, 2006 | 03:17 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Have you set up the XDF and ADS to do this? You need to link the two in the XDF header first, then go through the items you want to trace and edit the XDF item to link to the ADS item.
Old Feb 25, 2006 | 10:11 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yes i did that, i've done it on the $8D code, i'll give it another try
Old Feb 27, 2006 | 08:57 AM
ty1295's Avatar
i have been working on the $58 files that we try to keep updated on nwstp.com
It works on my end. You do have to make sure you keep the def. files linked, and not move them around.
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
