What is CJW 5816 Prom for, 1983 LG4 or L69 5.0L?
Car: 2000 BMW M5
What is CJW 5816 Prom for, 1984 LG4 or L69 5.0L?
Hi guys, I just got a 6455 ECM with a CJW 5816 Prom. They are supposedly out of a 1984 L69 305 (high output 4 bbl CCC Qjet, dual snorkle) Firebird. Can anyone verify this? I need to know if it is in fact for the L69, and not the LG4, since I am wiring this mostly from scratch and need to know whether or not to incorporate ESC circuitry (84 L69 had a knock sensor and knock filter, 84 LG4 did not. I have the sensor and filter but need to know whether my chip uses it)
Thanks!!!
Thanks!!!
Car: 2000 BMW M5
32V, the ECU is assembled. Would I have to unsolder the prom from the circuitboard? I have worked on the later ECUs that use the memcals, but not an early one like this. Also what do I use to check individual bytes? I have Tunerpro RT.
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
can't say if the firebirds were different or not but I know my L69, 5-speed's PROM number is 5838cjz (discontinued california emissions chip) and that the non-california chip is 5822cjx.
Why would I know this? I'm in the middle of trying to hunt down the discontinued chip since mine seems to be bad at the moment...hope that helps somewhat. :P
