Trying to datalog...
Old Mar 1, 2006 | 05:54 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I got the ALDU1 converter and the CABL1 OBD1 connector. I hooked everything up and cannot connect to the "hardware." I selected Com port 3 and tunerpro RT verified it. I then try and connect and it fails. And when I goto check the com port again, it say's, "not found." But, as soon as I restart the program again, its magically found once more! -Still won't connect though. Anyone know whats up?
PS: SES light blinks when connected.
Old Mar 1, 2006 | 06:31 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
You got the switch on your aldu1 in the grounded position, this puts your ecm in diag mode. Try it with the switch in the center or
up position. The switch should be on the right side of the cable.
Old Mar 1, 2006 | 10:18 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
also check in the "Tools" tab go to "Preferences", then go to ALDL/Emulation & see what the interface type is set to, i think you should be set to MAX232.
396V8
Jun 16, 2009 07:02 AM
1500chevy5.7l
Jan 25, 2008 04:28 PM
