8f 3 bar
Old Mar 10, 2006 | 10:50 AM
all spooled up's Avatar
Car: 89 IROC-Z / Turbo Grand Prix
Engine: 406 MPFI / 3.1 intercooled turbo
Transmission: 700r4 / HM282 5 speed
Axle/Gears: 4.10 / 3.91
8f 3 bar
Hey guys,Me and some of the boys at the tgpforums are reaching the limits of the 2 bar set up.We are becoming very familar with the the 8f code and were wondering if we could incorporate a 3 bar patch in it.Can we use the 58 3 bar patch?If not what would half to be done to make this work?Also what kind of changes will half to be made to the xdf file? Any help would be appreciated,Later
Old Mar 10, 2006 | 12:44 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: 8f 3 bar
You need to disassemble the code, and then work on commenting it. Then you can identify where the 2 bar math is done, and modify that to being 3 bar.
Once, you have commented code to work with the sky is the limit.
Old Mar 11, 2006 | 07:22 AM
Grumpy thanks for ur qwick reply,there are not enough reasources at the tgpforums to get this done.The tgpforums has a handfull of brilliant tuners but as far as I know none of them have access to a assembler/disassembler.Would anybody here be willing to help us step up to the next level of performance?Any help will be greatly appreciated by the entire tgpforums community. Later
Old Mar 11, 2006 | 09:48 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Chapter 7 of the "Tuning Guide" in the stickies.
https://www.thirdgen.org/techbb2/sho...de+for+dummies
Long thread with the whole process laid out.
As you read it you will see the common issues that raise questions.
Work with it (It does take time) and it will become clearer.
Most of the thread concerns $8D but the processes apply to all.
Old Mar 11, 2006 | 10:16 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
All you *need* is yourself, and the desire to learn, and do it.
If you're going to wait around for someone else to do all the work, it's unlikely much will get done.
Old Mar 11, 2006 | 11:04 AM
Thanks guys for POINTING me in the right direction.I agree about doing it myself if I waited for someone to else to tune my car I would still be waiting.We'll keep diggin into this and I'm sure I'll be back soon. Thanks again Later
Old Mar 11, 2006 | 11:38 AM
ryan.h's Avatar
I think a large part of the problem is the 8F isn't completely commented yet. I mean it's about 50% there last time I checked, but seeing as how it's very similar to the A1, I'd check into comparing the code between them.
Old Mar 11, 2006 | 02:12 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Both of the $8F and $58 that I have seen publicly available has a fair amount of mistakes in them. You would be better off starting out with a fresh disassemble and go from there. Use the public stuff as a comparison.
I started out with the public $58. I worked with it for a while and then just threw it out and started fresh. It wasn't worth deleting stuff and fixing it because there really wasn't much usable info in it anyway.
The $8F and $58 are kind of similiar. Could use just dissamble a 3bar $58, compare it to a $58 to see what was done and then drop it in the $8F. Seems like the most simple/quickest way to go.
Baldwin's AS6811 is a good assembler and is public for non-commercial use. The guy that scammed the DIYWB project has one to. I wouldn't use that one.
Old Mar 11, 2006 | 02:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Is your new and improved version public domained?.
Old Mar 11, 2006 | 05:31 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Nah, not yet. I decided to do another turbo vehicle this winter so it took up a lot of time. Then I started messing with intercoolers & learning to TIG weld so that chewed up more time. The $58 is about 1/3 to 1/2 done. Too early to release it yet.
It is like fabbing stuff. I do it only when I feel like it. That way I don't feel like I spent all of my time on it and get all protective about it.
I will be back to tuning the turbo rig in about a month so work on the commenting should resume. Yeah, it will be released when I get it done. It won't really be improved, just more comments in the file and I/O relationship info. to the hardware.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
