Iac & $58
Old Mar 13, 2006 | 04:29 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Iac & $58
i think before i switch back to $8D i'll try a different $58 bin, question is on the IAC on this board there are 50 million ways to wire it, it's my understanding that on a 1992 SD TPI 7730 that there is no need to re wire the IAC, i took the iac out and with the 7730/$58 and key on it extends all the way, key off and it retracts around half way, does that sound right? i'd like to get the $58 running instead of $8D
Old Mar 13, 2006 | 06:22 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Iac & $58
Originally posted by 86Z
Key on, A->B shorted, should cause the IAC to run, and extend itself.
If you unplug the IAC with the key still on, then key off, and then remove it, it should be fully extended.
Old Mar 13, 2006 | 06:39 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
thanks grumpy thats how mine is working, but i cant get the $58 code to idle at the set idle speed, and tunerpro is saying 76 counts at idle, i tried the minimum air adjustment and fired it up and it ran about 1200-1300 rpms...
Old Mar 13, 2006 | 07:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The 58 has a bit of it's own mind about IAC counts.
there's also MPH reset as I recall, unless you hit 25 (?) MPH it may act up. Once it does the VSS reset, it should be OK.
Just going from memory since it's been a while since I ran it.
Old Mar 13, 2006 | 07:59 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Another interesting thing about the $58 code is that if you use the normal 10k resistor on the ALDL plug it will force itself to a 1200 RPM idle. That would mess you up also.
It sounds like you have the 10K resistor installed. You can still 8192 datalog without it.
Yes, your IAC is operating correctly. Did you leave the IAC wiring as stock 730 ECM wiring?
Old Mar 13, 2006 | 08:07 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yes stock wiring for the 7730 SD, no resistor installed using a moates serial to usb, and an ostrich, it has the switch to either short a and b or the 10k, thats why i dont understand why the idle is messed up.
Old Mar 13, 2006 | 08:25 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I NEVER start an new ECM and/or engine using an emulator. My early designed emulators would screw up an ECM parameter sometimes when the ECM reads from the PROM. Yeah, I eventually figured out how to fix it, but I learned to keep things simple on initial start up with a new ECM/engine.
This may not have anything to do with the odd idle thing, but you can rule one thing out while learning the new ECM.
I am not knocking your emulation equip, it just adds another level of complexity. Good to hear you kept the stock IAC wiring.
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
