question on s_aujp_v3
Old Apr 2, 2006 | 01:11 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
I got the bin for s_aujp_v3 from the moates file site.
I proceeded to modify my own bin and edit the ve upper rpm table using TunerProRT. Is that really all there is to it? Or am I missing something?
Old Apr 3, 2006 | 10:02 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
s_aujp_v3 has the hard-code modified to actually make use of the extended upper VE table.. Just editing a standard bin with TunerPro isn't enough, the standard bin doesn't even read the locations you are writing to.
Old Apr 3, 2006 | 12:36 PM
Axle/Gears: 4.1
Hmmm...interesting.
So, if the S_AUJP_V3 has all the code, then would it be true that all I have to do is edit the S_AUJP_V3 to what I want?
Old Apr 3, 2006 | 03:08 PM
thirdgen88's Avatar
Car: 1995 Corvette
Yes, you can edit the SAUJP_V3 in the extended VE table and realize your changes...
Old Apr 3, 2006 | 03:35 PM
Axle/Gears: 4.1
OK, I edited the S_aujp_v3...
with my RamJet 350 parameters and burned a chip.
I edited the Upper RPM table and did some other minor changes to more closely match my fairly well running Ramjet combo.
Now to see what she does.......
Old Nov 3, 2006 | 12:42 PM
derkzen's Avatar
I have the s_aujp_v3 bin what about the xdf file? does any one have this?
Old Nov 3, 2006 | 05:29 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
In the note file that comes with the bin it explains the ECU file to use.
Import it into TP to convert it into the XDF format.
Then go
Old Nov 4, 2006 | 01:57 PM
derkzen's Avatar
thank you for your help i'll try that
Old Nov 5, 2006 | 05:11 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Where can I down load s aujp v3, moates new web sight doesn't have it anymore or
anyothers or did I just miss it thanks
Old Nov 5, 2006 | 11:12 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
ttt
Old Nov 6, 2006 | 05:04 PM
JP86SS's Avatar
Its still there you just have to hunt for it in the menus.
Bottom of the Documentation link.
Old Nov 7, 2006 | 05:05 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Anynoe still woking on v4
Old Nov 7, 2006 | 07:19 PM
JP86SS's Avatar
Yup
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
