Help me understand these relationships please
As I mentioned in my earlier post, I am starting from a stock bin for this next tune. As I was wondering through Tuner Pro, I came across three things that I *think* are related to O/L idle in the 7747.ecu. They seem each contradict each other, so could somebody tell me how they realate
They are:
O/L AFR vs Temp...............the base for O/L AFR calculations?
Time Out AFR vs Cool-->Choke (subtracted from AFR vs Temp) .............subtracted from O/L AFR vs Temp ie. 13.00 (O/L AFR) - 3.00 (Time Out AFR) =10.00 to 1 AFR?
Cold AFR vs Kpa.........is this added to (lean) or subtracted from (richer) the value of one or both of the above values under load?
TIA!
They are:
TIA!
Car: check
Engine: check
Transmission: check
These two tables get added together to form the commanded AFR:
This table is subtracted to enrich the AFR. It decays out over time, slower when cold, faster when warm:
'747 open loop fueling. PE/WOT mode has it's own commanded AFR table. Which is compared to the open loop value and the richer of the two is selected.
RBob.
RBob.
