Disabling VATS with $8D
Old Apr 3, 2006 | 01:33 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Sorry, I'm sure this question has been asked a billion times, but doing a search didn't turn up anything useful, so I figured I'd make a post, and get a definitive answer of sorts that can be searched in the future.
I'm fairly new to prom burning, and I need to disable VATS. However, my definition file isn't very clear about what the different VATS flags are. Simply states "Switch 16 (VATS TTC-R 4th-NO VATS OLP) - Bit x"
Where x is replaced with a number 0 - 7. Which bit is the one that I need to be unsetting? Bits 4 and 1 are both set, the rest are not.
Old Apr 3, 2006 | 08:43 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Alright!
I did a bunch more searching, and finally found what I was looking for
Its bit number 4 that needs to be unchecked to disable vats.
Code:
L8016:        .byte   0x10    ; AFR OPTION WORD 1         0001 0100
                              ; DRef: 0xD8B6,0xD936,0xB35D,0xCF3E,0xD03C,0xE140
                              ; b7, 1 = --
                              ; b6, 1 = USE A/D BATT FOR INJ Lk Up, (else use PUMP VDC)
                              ; b5, 1 = OPEN LOOP PURGE
                              ; b4 ,1 = ENABLE VATS
                              ; b3, 1 = LET LOW TPS DISABLE CCP
                              ; b2, 1 = 4TH GEAR SWITCH N.O.
                              ; b1, 1 = 16 Hz CCP SOLENIOD IN USE
                              ; b0, 1 = RPM FOR TCC vs MPH
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
