SA Tables
Old Apr 26, 2006 | 12:43 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
SA Tables
I've got a chip that im working on with BMmonte. He has set up a SA tables for me to try, when adjusting the SA tables, can I just cut all the values in the table by half to reduce the spark advance. Or do i need the adjust different cells differently. Thanks!
Old Apr 26, 2006 | 12:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Cutting the values in half will work. May be a bit drastic depending upon the current value. Usually what is done is to reduce the whole table by a particular timing value. Can pull 4 degrees out of every location.
One thing you can do is to take the difference between your original table and the new table. Halve the difference and add that back in to the original table for the new BIN.
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
