Where is my fan temperature setting?
Old May 16, 2006 | 12:51 PM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Transmission: Auto w/ TransGo shift kit
Probably this is a dumb question but I can't find the temperature setting for my fan.
I've downloaded the bin from my IC and xdf I'm using is JP's 61 v2.
I've been through all the Constants (and Tables too) but I can't find it. Am I that stupid (OK, you don't have to answer this question)?
Old May 16, 2006 | 01:12 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The fan is controlled by a switch in the pass. side head.
Old May 16, 2006 | 02:30 PM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Sorry, my mistake for not explaining this very well. I'm looking for the Temperature Fan Constants in the PROM not the fan sensor.
I'm modifying my PROM using TunerPro and I can't find the constants the set the Fan On an Fan Off temperatures.
Old May 16, 2006 | 02:52 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Are you using a stock 91 TBI ecm? If yes... re-read the folowing:
As far as I know the ecm has no control over the fan. The fan switch in the cylinder head grounds the fan relay coil at a certain temperature (stock is 220F).
Old May 16, 2006 | 04:14 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Hi im a newbe in tuning the ecm, but I know there is a way the ecm controls the fans, because I have seen someone change the on/off in there ecm but dont know the codes. Im going to have to find out myself also.
Old May 16, 2006 | 04:26 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Good possibility your ECM does control one of the two fans, Z28 w/TPI? Then it does, has the '730 with the $8D mask.
For the TBI, no, the ECM does not control the fan, the switch in the passenger side head between 6 & 8 does.
RBob.
Old May 16, 2006 | 04:45 PM
DM91RS's Avatar
Car: 91 RS
RBob.
Unless someone was running that EBL thing!
Old May 16, 2006 | 05:14 PM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Oh well, I was hoping I could do it via ECM.
Is there a sensor that would reduce the temp to 170F?
DM91RS, what's EBL?
Old May 16, 2006 | 06:05 PM
DM91RS, what's EBL?
Sort of, I think Jet makes them. Summit is a distributor of these fan switches. Temps I know of are:
220 on; 200 off
200 on; 185 off
180 on; 165 off
Old May 16, 2006 | 07:18 PM
DM91RS's Avatar
Car: 91 RS
DM91RS, what's EBL?
Read here https://www.thirdgen.org/forums/diy-...?highlight=EBL
The fan control is one of many reasons you would like it. I do!!
krisner89
Oct 10, 2015 06:03 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
