1226870 ecm file $1F
Old May 18, 2006 | 07:58 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Does anybody have this ecm file that I can use with tunerpro.
If not will the one tunercat sells work.
Old May 18, 2006 | 09:01 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
File Manager - Browsing directory /3) Binary Editor Definitions/1) TunerPro XDF Files/1) General Motors/
Old May 19, 2006 | 07:54 AM
seiplentz's Avatar
Car: 85 Z28
Thanks for the help.
I am new to trying prom burning. I saved that file do I have to build the ecm file in tunerpro and save it or can I just resave the file to open as a xdf or ecm file.
Old May 19, 2006 | 10:43 AM
Mangus's Avatar
Transmission: T5WC
I don't understand the question. Do you need a bin file too? It is normally recommended that you start with the stock bin for your vehicle. This is best if you read it directly from your vehicle's stock chip. If are not able to do that, look for the stock bin in the bin library at ftp.diy-efi.org
Old May 19, 2006 | 02:20 PM
seiplentz's Avatar
Car: 85 Z28
Im sorry if I wasn't clear. The ecm file I downloaded was a html document not an xdf so I was not able to load it into tunerpro as the ecm file. I tried resaving it as a .xdf and a .txt but was unsecessfull loading it. So I just need to know what I need to do with the ecm file. I have a stock bin from a 85 vette I am going to start with.
Old May 19, 2006 | 03:17 PM
Mangus's Avatar
Transmission: T5WC
Click on the link in my first post. Find 1F.xdf. Right-click and choose "Save as". Save it as 1F.xdf.
Old May 19, 2006 | 07:55 PM
seiplentz's Avatar
Car: 85 Z28
Duh, I am a retart!
But I did figure it out before I read the post.
By the way would you or anybody happen to know if the prominator will work with the 870 ecm. I want in the group purchase.
Thanks again for the help.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
