Serial to USB Adapter (ALDL Cable) run w/out External PWR Source???
Old May 23, 2006 | 12:17 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
The ALDL cable I want to get has its own pwr source from the serial port. I will have to use a serial to USB adapter and need to know if this cable will work with the adapter...
Does the USB support power or do I have to use an external power source??? (My cig lighter is going for a shift light)
Old May 23, 2006 | 05:43 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
The usb to serial convertor will use the power from your computer. You shouldn't need any external power source. Plug the usb to your usb port, other end goes to the convertor box, which leads to the ALDL connector.
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Elliswon
Aug 10, 2015 12:33 PM
Kaweh
Aug 9, 2015 02:54 PM
