Need help with new setup
Old May 26, 2006 | 07:13 AM
gt500pwr's Avatar
I just got my burn1 unit from moates. Car is 1991 camaro RS 305 l03. ecm is 8746 and i put a jet stage II chip in about 8 years ago. I've got the stock chip and on the sticker says ANTT. I read the chip and used the 61.xdf for tuner pro and opened the bin. If I click on things like PROM ID, or # of cylinders the data isn't correct. I also tried with a stock ANTT from moates with the same problems. I'd like to compare my stock with the jet chip to better understand the configuration differences. Any suggestions?
Thanks.
Old May 26, 2006 | 12:19 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Took a quick look at it
I'd say to read the chip the same way you do the aftermarket one and compare them that way.
(to be sure anyway)
Actually looking at the bin in a hex editor indicates it doesn't start until $1000.
The bin is offset to that address but the XDF's were not.
In the XDF header info, change the base offset to 1000.
Looks much better.
Old May 26, 2006 | 04:23 PM
gt500pwr's Avatar
You were right, i changed the offset to 1000 and suddenly all looked correct. I'm confused though, i rechecked the antt bin and checked the egr flag and it's not set but there's definitely an EGR?
Old May 28, 2006 | 05:16 PM
gt500pwr's Avatar
Anybody?
Old May 28, 2006 | 07:06 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You can have the pieces for EGR, but that doesn't mean it's enabled to work in the chip (assuming it's solenoid controlled).
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
