Programmer for 2532 EPROM
Old May 26, 2006 | 10:53 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Who makes an an affordable programmer for the 2532 eproms? I have a CC Qjet setup and would like to program a 350HO bin to install in the 1228079 ECM, then later on tweak it.
Old May 26, 2006 | 11:06 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The PPII can, but youd probably be better off converting the ECM over to use flash or some other later memory. It takes some soldering, but if you have the pinouts for the chip, then you can make an adaptor. It will be alot easier then trying to UV erase and program ancient 25 year old chips.
Old May 26, 2006 | 11:21 PM
trumps2000's Avatar
Car: 1985 Z28
Thats a good idea I didn't think of that! Being an electrical engineer I should be able to pull it off. It'd be sweet to be able to program it with a serial cable and without removing anything.
Thanks for the sweet idea dimented24x7.
Old May 27, 2006 | 11:43 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Montecarslow has done that through the ALDL port. I think its still on the first few pages. I just use 27SF512's with the PPII.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
-=Z28=-
Sep 24, 2015 10:21 AM
f-bodyz28
Sep 2, 2015 05:03 PM
the_nikfive
Aug 11, 2015 02:46 AM
