Finetuning a 7730...
Old May 29, 2006 | 02:01 AM
JariV's Avatar
Car: Several, all with 8 cyl. Some bigger, some smaller
Engine: Ranging from L8 4,4 liter to over 9,2 liters full aluminum V config.
Transmission: Which one?
Hello,
can anybody give me an advice from which table or constant I could try to tune away the following fuction described below the photo:
Engine (350 hopped up but not a hell of a lot), factory STD hyd. roller 1990, 10,4 comp, Vette aluminum ported heads, homemade FI intake, headers, a light car 2550 lb. Trans is a 700. 3,90 gears in Pherd 9".
Here:
Now, the engine is in 180-190F range and cruising @about 40. Once you touch the gas VERY LIGHTLY it hesitates, if you push it further or all the way to the floor everthing rocks as it should. Where can I seek the problem? And how to cure?
TunerPro and Ostrich in use. All mech. aspects in engine ok, fuelpress ok.
So, which table needs TLC?
Maybe increase the TPS multiplier with small delta TPS? Or?
Old May 29, 2006 | 02:18 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'd probably try the AE vs TPS% table, but the gurus around here will probably disagree and provide a better answer. Honestly, I'm still learning all this stuff myself...
Old May 29, 2006 | 06:45 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
That would be one place to start.
Thou, you need to look at timing, and when all else fails, you might use the VE table to *crutch* up a lean area.
There's no pat answer for you, it's a matter of experimenting (taking notes), and looking for trends. ie sometimes it might take using 4-5 items, and getting the blending of all of them correct to get a car glass smooth.
SweetRide45
Dec 17, 2007 03:10 PM
thunderstick
May 21, 2005 04:32 PM
2new2funny
Nov 7, 2004 12:34 AM
Mark A 91Formula
Sep 30, 2004 09:09 AM
