air fuel ratio @ idle when cold
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am curious if all I need to do is change the air fuel ratio table to richen up befor the car warms up.
or is there a better table just for the idle range? in 6e.
the cam has a bit more overlap than stock, has aftermarket heads , hsr and longtubes so on..... and I am 99% sure it needs more fuel until it warms up since it idles better with the stock inj constant.
kyle5647
Aug 15, 2015 11:56 PM
