7747 Pump shot...
Old Sep 30, 2000 | 12:30 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
7747 Pump shot...
I finally got my functional PROM programmer and I've been playing with the TPS pump shot table. Unfortunatly, I'm not sure I understand it. Here's what the table I'm starting with looks like (this doesn't work, it still backfires with this table)...
%TPS usec Added
0.0 122
3.1 305
6.3 610
9.4 916
12.5 1221
15.6 1526
18.8 1648
21.9 1953
25.0 2441
Just messing around with it I increased the values in increments of 10%-20% down the whole chart, and it seemed to do better with quick throttle openings. I'm now trying leaving the 0% TPS value at 122 and increasing the others by fixed amounts, 400usec, because the idle was increasingly crappy as I played with the table. Anyone have an explanation of these values and suggestions for tuning this table? Thanks...
-Mark W.
<A HREF="http://www.angelfire.com/al3/thegreycar">'88 SC Camaro w/ 305 TBI</A>
Old Sep 30, 2000 | 06:21 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
dont be afraid to really boost up the numbers
this chart will have no effect on idle (well, im pretty sure any other cell other than 0% tps wont have an effect, i still dont understand the 0% myself it would seem like that is added all the time, so i dont mess with it)
just download some Bins from larger motors, and then use those, and play with them
as a suggestion, find a 454 bin with the smallest amount of pump shot out of the 454 bins you see, and just use the TPS pump shot and leave the map pump shot alone, this is considerably less than what the 454 uses but alot more than what the 305 uses stock and is a good start
Old Sep 30, 2000 | 06:24 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
btw those are still way way too low, my setup is still a little lean on the pump shot and i have double what you have there on the high end of the scale
BTW you are also gonna need some tuning beyond just pump shot your motor is ingesting alot more air now the top end is probably a little lean
Old Sep 30, 2000 | 07:47 PM
Mark305TBI's Avatar
I got the Pump Shot table working...Increased everything past 0% by a factor of 3.3. It rev's quick with no sputter or backfire.
Only problem (non-pump shot related) is that I can't get the damn thing leaned out at idle. What can I adjust to help lean it out? I've got the 65# injectors on my Holley TBI unit.
-Mark W.
Old Sep 30, 2000 | 08:20 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
oooh those injectors are way way more than what you had stock
have you done anything else to the chip?
if not, drop the BPW to 112, it should REALLY improve things for you
give me a buzz on icq 11291690, i can talk you through this easy stuff and im dying to hear the difference the bpw adjustment makes because right now you are running PIG RICH
Old Sep 30, 2000 | 08:25 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
btw at what amount of vacuum are you idling at?
Old Sep 30, 2000 | 08:27 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
oh, you might have to make a pump shot adjustment after you change your bpw but i dont think you will need to
Old Oct 1, 2000 | 11:43 AM
Mark305TBI's Avatar
I've got the BPW turned down to 112...
Made the pump shot adjustments with it at that, so no more pump shot tuning is required. It doesn't make a difference, still runs rich as sheet.
I'll try to get in touch ICQ at some point today, couldn't yesterday...I was busy yelling profanities at Fulmer and the Vols, I hate football...
-Mark W.
[This message has been edited by Mark305TBI (edited October 01, 2000).]
Old Oct 1, 2000 | 05:30 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
it had to have made a difference, from 135 to 112 is huge
its possible its still rich, but trust me it made a difference
Old Oct 1, 2000 | 07:18 PM
Mark305TBI's Avatar
The O2 sensor wire bundle was touching the header. I repaired the burn damage and used a wire tie to pull it out of harms way. Now, I put my chip into the ECU and it runs idles 100% better. So I pull it again and make some small adjustments to some other stuff that wasn't quite right. I write those changes to another chip and run back out to the car and slap it in there. The damn thing wouldn't even start. I figure that I've made some strange mistake in tuning so I put the first chip back in there. It does the same damn thing! Starts, sputters, and dies immediatly... I'm going to try again here in a minute with the first chip and see what it does now. After giving the car 12 hours to change its mind about not running right .
-Mark W.
Old Oct 1, 2000 | 07:26 PM
Mark305TBI's Avatar
P.S.
What do you think about this pump shot table? Too much? I thought they looked kinda on the large side, should they increase more slowly or does this look about right?
%TPS usec added
0.0 122
3.1 1099
6.3 2197
9.4 3296
12.5 4395
15.6 5493
18.8 5920
21.9 7019
25.0 8789
-Mark W.
Old Oct 1, 2000 | 07:54 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
that doesnt look too bad, i dont have my cats program open right now so i cant compare line by line but it looks alot like some of the 454 pump shot setups
give me a buzz on ICQ allready
Old Oct 1, 2000 | 08:42 PM
Mark305TBI's Avatar
Working on it, ICQ software is downloading now!
-Mark W.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
