Cal Pack? What does it really do?
Old Oct 2, 2000 | 08:55 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Huh? Does anyone really know? Does it do more than just control the limp home calibration? Just curious...
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Oct 3, 2000 | 02:22 AM
Dan W's Avatar
My understanding is it contains vehicle specific data... tranny type, type of emissions system, etc.
Old Oct 3, 2000 | 07:39 AM
FastBroker's Avatar
CALPAC does contain that stuff but it basically is there in case of a PROM meltdown. The CALPAC information (CALibration) will be used by the computer to get you home in limp-home mode. Therefore, if the CALPAC info is off by a large margin, as would happen if you susbstantially modify your engine, it will be difficult/imposible to drive home in limp home mode... but don't worry about it...
Old Oct 3, 2000 | 11:22 AM
Mark305TBI's Avatar
So, in theory, if you were to drive your car totally without it...You'd never notice the difference unless your PROM chip was bad?
-Mark W.
Old Oct 3, 2000 | 03:49 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
im pretty sure it contains the information dan posted, especially pertinent is the number of cylinders the ecm is being used on
the 7747 was used on alot of stuff i think some 4 bangers and i know Alot of 6 bangers and im pretty sure that chip determines the number of cylinders
Old Oct 4, 2000 | 08:13 AM
FastBroker's Avatar
I'm not sure if you can or not. But I know I wouldn't try it...
Old Oct 11, 2000 | 09:57 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I'm a little late replying to this, but I just remembered. I've had my IROC run in the limp-home mode before when I didn't have my ZIF socket soldered in good enough. I'm using an '87 350 memcal, but it runs my 305TPI good enough. Having only 22 degrees (or whatever it is) of total timing stinks, but at least it runs...
Fanatic1074
Oct 3, 2022 05:57 AM
Zell1luk
Sep 29, 2015 10:36 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
efiguy
Sep 27, 2015 01:30 PM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
