BPW change for larger injectors
Old Oct 11, 2000 | 01:49 AM
Brent's Avatar
Here is the backround. <cr>
1227747 <cr>
ARJT <cr>
truck 350ci auto (almost stock)<cr>
65lbs/hr inj's <cr>
The stock BPW is set to 135. The 65 lbs/hr injectors are 18% larger than the stk 55lbs/hr units.
I intend to decrease the BPW constant to 110, an 18% decrease, to compensate for the larger injectors.
Any thoughts/recommendations on this course of action?
Brent
Old Oct 11, 2000 | 11:57 AM
FastBroker's Avatar
I come up with 114.23, so use 114...
Actually, you should use the 114 for this PROM. Then, drive around with the new chip using a scan tool and watch the BLM's when the engine is fully warmed. If your BLM's are off across the board (away from 128) almost the same amount, you can simply make one more adjustment to the BPW instead of changing the entire VE table.
[This message has been edited by FastBroker (edited October 11, 2000).]
1992rs/ss
16
Jan 28, 2016 09:58 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
gta90
Sep 15, 2015 04:00 PM
bdads
Aug 24, 2015 06:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
