Knock Retard on Decel - 6E
Old Jun 13, 2006 | 09:20 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
About 1-3 degrees of KR occur when I rev and let off the throttle. As the rpm's are falling in the range of 6000 to 3000 RPM's, The ecm is pulling timing away. (This is with a low LV8-car in neutral), Is this normal? If not, how should I go about fixing it?
Old Jun 15, 2006 | 06:43 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I'd look at the usual mechanical suspects first.
Are you talking about a *free* rev?. If so, what's the point in doing that?. If it's not a normal drivibility thing, IMO, doin't go out of your way to cause problems.
Old Jun 15, 2006 | 10:26 PM
Dirtbik3r's Avatar
You do have a point. And yes, the same kind of snap throttle test you would do to check the tps graph on a scope. You know, that ant-hill looking formation... I was under the presumption that the more area's of the timing table covered, the better.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
efiguy
Sep 27, 2015 01:30 PM
ericjon262
Sep 11, 2015 06:07 PM
