89 vette chip, will it work in 87z?
Old Oct 31, 2000 | 09:19 PM
87Z-ya's Avatar
I know alot of people ask about the 89 vette chip. But no one has asked if you try to use the 89vette chip in a older z does the vats make a difference? My car does not have vats and i would like to get a 89 vette chip as a band aid till i can get dfi. Also how much do they usually cost at a gm dealer?
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 24lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.(stock 305 hypercrap chip), other stealth goodies.
Runs 14's all day long.
Old Nov 1, 2000 | 12:48 AM
Blade's Avatar
Sorry... No it woudln't work. Trust me... I've already tried it. First there's Vats, then the 89 chip has a different "mask ID" therefore making it incompatible with your ECM in its stock unmodified version. If you really want to make it work, email me privately and I'll adapt one from an 89 vette for your 87 Z.
Old Nov 1, 2000 | 06:10 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I've been told by several friends on the GMECM list that all you have to do is disable VATS with TunerCAT and burn it in and you're good to go. It get's rid of the cold start injector and that's about it.
I'm just going by what I've heard...I'm going to use the ARAP bin(89 350 IROC) here pretty soon as a starting point for my 87 305 TPI application. I'm just gonna disable the VATS. What mask ID do you need to plug into it? Or can you change that in Tuner CAT? I've seen the PROM ID # that changes to 0 the second you make a modification to it.
GregF
87 IROC
[This message has been edited by gsf-87IROC (edited November 01, 2000).]
Old Nov 1, 2000 | 08:56 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Blade,
Your post is confusing. You said...
Could you explain what you mean in more detail. You can easily run $6E code ('89) in ANY 165 ECM. Why are you saying that you need to modify the ECM? Many tuners here have run the $6E code (particularly the ARAP) in 1986-1988 165 ECMs. In fact, this exactly what TPIS does when a customer wants to run the MiniRam in a 1986-1988 F or Y body. The MiniRam has no provision for the cold start injector. Thus, they upgrade the code to $6E code (which doesn't use the cold start injector). Works like a charm.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Nov 1, 2000 | 10:21 AM
Blade's Avatar
Originally posted by TRAXION:
Blade,
Tim
I was reffering to the .bin file in its stock unmodified form. Not the ECM itself ! I can see how that is confusing now... What I mean is you have to edit it and take out the VATS functions if you're gonna use it in a non-VATS car.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
