Best UV eraser for Calpak
Old Oct 30, 2000 | 02:18 PM
89vette's Avatar
Looking for a cheap UV Erasor to erase my chip that is in my calpak. I heard the Datarase II works but you can't close the door. Also has anyone sucessfully used an emulator with a 165 ECM?
89 Vette 6 speed
CNC heads, crane cam, Super Ram, headers
Old Oct 30, 2000 | 02:21 PM
Blade's Avatar
You can trick Datarase very easily into thinking the door is closed. It's just a little switch at the edge of it that needs to be pushed in. Why not take the chip off the calpak and put a ZIF holder in its place ? Wouldn't that make things a lot easier ?
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 30, 2000 | 02:31 PM
89vette's Avatar
Becasue I'm afraid I'll ruin the calpack. I have the ZIF socket. Want to do it for me? :-)
89 Vette 6 speed
Old Oct 30, 2000 | 06:36 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
You won't ruin the MemCal. I do it all the time. Just put the EPROM portion of the MemCal in the DataRase with the other end hanging over the side. Rig the datarase to run with the cover open. Then, turn the DataRase on WITHOUT looking at the light and then walk out of the room and close the door. Come back later after it has turned off. Works great.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Oct 30, 2000 | 06:40 PM
Blade's Avatar
I think he means he'll ruin the calpak by trying to desolder it. If you can't find anyone to dot it I'll do it for you.... All it takes is about 5 minutes. All you need a soldering iron and patience to do it...
Old Nov 2, 2000 | 05:54 AM
Tomcat's Avatar
I modified my datamaster by drilling a hole in the base in line with the globe and hold the memcal on with a rubber band - can leave it on without the kids getting zapped by looking at it and don't need to modify the switch. I still use the hatch when when erasing eproms.
Just a thought from downunder
Daniel Collins
400 69 pontiac Firebird
Converted to injection
mike89z
Sep 5, 2002 10:53 AM
lars92RS
May 22, 2001 05:35 PM
leirch
Mar 2, 2001 09:06 PM
doc
Feb 13, 2001 01:58 PM
David 91RS/Z28
Oct 6, 2000 08:41 PM
