will a 87 tpi prom work in my 87 lg4 ecm?
Old Oct 30, 2000 | 07:59 PM
formula5's Avatar
Would it even be worth upgrading to the 87 ecm?
Old Oct 30, 2000 | 09:24 PM
Blade's Avatar
The PROM wont work. I doubt it's worth upgrading your ECM. Especially if you're doing it for an LG4 with a Q-Jet on it. The Q-Jet doesnt need a high (or higher) performance ECM to control it.
[This message has been edited by Blade (edited October 30, 2000).]
Old Oct 30, 2000 | 10:54 PM
formula5's Avatar
I should have been more specific,sorry.I have a 87 lg4 fomula.I am planning to put an 85 tpi unit on it.I can either use the 85 harness + ecm or get a 87 tpi harness and change the existing lg4 prom and keep the 87 ecm.If I use the 85 harness there will be some simple splicing.I just got a prom from a 87 tpi t/a.So if I can use my 87 lg4 ecm w/my 87 305 tpi prom and then I'll just need a 87 harness.I would rather not cut the factory harness and simply clip one in.From what I understand the 87 ecm has a faster data stream or something.Which ecm is better 85 or 87.I think the 87 would be better but is it worth it?
Old Nov 17, 2000 | 03:18 PM
formula5's Avatar
Old Nov 17, 2000 | 04:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The 87 Carb ECM cannot control the TPI system. They're completely different. Your best bet is to get an 86 or 87 TPI computer and wire harness, because the 85 stuff stinks.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 17, 2000 | 07:27 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The 85 TPI ecm is an antique, the 87 TPI ecm is *OK*,
The 87 TPI ecm is fairly close to a LG4 harnes. For all that ork thou, you'd be much further ahead to use the 90-92 ecm, then you can drop the MAF sensor, and go MAP.
The 87 CCC carb is useful for CCC applications
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
djmarch
Aug 11, 2015 10:22 AM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
